Arc Flash Forum
Documents that list Shock Protection approach boundaries....
https://brainfiller.com/arcflashforum/viewtopic.php?f=14&t=5456
Page 1 of 1
Author:  wfg42438 [ Tue May 11, 2021 2:50 pm ]
Post subject:  Documents that list Shock Protection approach boundaries....
Hello Everyone,
As many of you are aware documents like NFPA 70E 2021 publish shock protection boundaries for energized equipment(See image sampled from NFPA 70E).
After doing some research I saw that there is more than one document out there with shock protection boundary recommendations.
Some examples of documents that also publish Shock Approach boundaries are listed below:
Brazil: NR-10
(http://www.braziliannr.com/brazilian-regulatory-st...)
Canada: Z462
Great Brittan: EN 501110-1:2013
Im curious if anyone out there knows of other documents similar to the samples I listed above especially if there is one that used out in Australia that differs from NFPA 70E.
Any help with this inquiry would be much appreciated!
Shock.tif
http://www.phpbb.com/
