Arc Flash Forum
SKM Arc Flash Calculations
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=5125
Page 1 of 1
Author:  mham [ Fri Jun 21, 2019 8:01 am ]
Post subject:  SKM Arc Flash Calculations
Hello! I'm wondering if it makes more sense to use actual VS SKM default values when you are looking at this graph (attached). Would it be better to use the actual trip value or the default SKM gives you? I feel like it would be better to use the actual trip value, but I'm not 100% sure.
http://www.phpbb.com/
