Arc Flash Forum
Fused Disconnect Modeling
https://brainfiller.com/arcflashforum/viewtopic.php?f=23&t=6397
Page 1 of 1
Author:  arcflashprimero [ Thu Jan 29, 2026 1:28 pm ]
Post subject:  Fused Disconnect Modeling
I am currently on a site that has a disconnect with 3 different fuses inside. How would you model this?
Author:  bbaumer [ Thu Jan 29, 2026 5:09 pm ]
Post subject:  Re: Fused Disconnect Modeling
Got a pic? Like 3 different brands but same amp and type or 3 different types or 3 different amp ratings or some combination of the above?
For example, (from memory) Buss Frs-R-100, Gould trs100r and Littelfuse FLSR100? All are the same curve. Pick one.
Author:  arcflashprimero [ Fri Jan 30, 2026 3:50 am ]
I modeled them below. All 50A, curves are slightly different
Author:  Win Engineer [ Fri Jan 30, 2026 6:49 am ]
As long as they are all RK5 fuses with the proper voltage rating, I generally just pick one and put a note on the drawing that the switch has fuses from different manufactures. If you have RK5 and RK1 fuses in the same switch I will model with the RK5.
Author:  bbaumer [ Fri Jan 30, 2026 8:41 am ]
This. ^^^^^^
http://www.phpbb.com/
