Arc Flash Forum
Dates on Labels
https://brainfiller.com/arcflashforum/viewtopic.php?f=24&t=1461
Page 1 of 1
Author:  McFlash [ Wed Dec 29, 2010 2:46 pm ]
Post subject:  Dates on Labels
OK, i know many out there put dates on the labels that are printed for equipment, but in know that there are many others that do not. Is there any reason to put dates on labels. We are having internal discussions on this very topic. It seems if they are dated and you cross the 5 yr mark and don't update all labels it gets confusing if the study was actually updated or not. Any thoughts?
Author:  glen1971 [ Thu Dec 30, 2010 6:16 am ]
The company I work with put dates on their labels. It gives everyone a date that the study was done, and if there have been no changes to the system, they should be accurate. At least with the date on them you'd have a reference.
Author:  stevenal [ Thu Dec 30, 2010 9:35 am ]
I'm not too sure the question was understood. I find it an interesting question, so let me give an example for how I understand it. A facility performs a complete study every five years. At the time of the last study, location A had a change, so A was relabeled with a new IE and date. Location B had no change, and is still labeled with the same IE and old date. Location C had a change, but for some reason the new label never made it to location C, and it retains the old IE and date.
Also consider the same scenario with no dates.
Author:  cbauer [ Thu Dec 30, 2010 10:02 am ]
IMHO, I would put on all new labels, with the new date, on all equipment regardless if a change in IE occurred.
Author:  wbd [ Thu Dec 30, 2010 12:15 pm ]
I would think that this could be quite cumbersome and costly for a facility that is large. Think of a facility such as a GM or Ford plant.
I am thinking that maybe no date is ok as long as there is a mechanism to insure that a review/revision of the study is done every 5 years.
What happens if you initially date the labels when the study is first done and then 6 months later, a change is made somewhere in the plant that requires the study to be revised? Do you then go place new labels with the current revision/date of the study on it? Then 3 months later a breaker fails and a replacement that is not the same trip characteristics is installed. Study revised to incorporate this change, then new labels installed all over.
I really think one could spend alot of time and money on labels depending on the specific plant.
Author:  Robertefuhr [ Fri Dec 31, 2010 8:59 am ]
We put the date on the label as well as many other important items. The date on the label will give the reviewer an idea of when the study and labels were produced. The statements in NFPA 70E do not imply that the study and labels need to be reproduced every five years. See the attached example.
The study and electrical distribution system needs to be reviewed to see if any significant changes to the equipment or available fault currents (i.e. utility transformer size changes.) The review should also identify new equipment that has been added that does not have a label.
Motor Circuit.pdf [12.16 KiB]
Downloaded 317 times
Author:  A King [ Tue Jan 04, 2011 5:03 am ]
Dates on AF Labels
I think dates on labels are a good idea so that there is something to cross reference if in question. I would be sure to document audits; however, I wouldn't replace all labels simply because the date is from 5 years ago. As long as the no changes to the system have been made, the label is still good.
http://www.phpbb.com/
