Arc Flash Forum
Extension Cord Fault
https://brainfiller.com/arcflashforum/viewtopic.php?f=30&t=4377
Page 1 of 1
Author:  PAult [ Tue Jun 20, 2017 9:38 am ]
Post subject:  Extension Cord Fault
Using the extension cord as a disconnect for a 1/2HP motor caused the cord to catch on fire. GFCI or circuit breaker feeding the cord did not trip. 120VAC.
File comment: Cord Fault
Author:  BarryB [ Mon Jun 26, 2017 8:21 am ]
Post subject:  Re: Extension Cord Fault
Probably caused by excessive resistance at plug vs. over amperage. This would result in more heat than could normally be dissipated by the plug until it ignited.
Author:  JBD [ Mon Jun 26, 2017 8:28 am ]
Yeah, and there appears to be little to no damage around the ground pin, so it looks like a GFCI might not have noticed this event at all.
http://www.phpbb.com/
