Arc Flash Forum
Cheater Plug - Grounding
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=2611
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun Jan 27, 2013 3:07 pm ]
Post subject:  Cheater Plug - Grounding
Last week’s question about cutting the ground prong evolved into a discussion about what was planned as this week’s question regarding “cheater plugs” These are the plugs that “convert” a three prong input into a two prong output.
This week’s question: Have you or anyone you know ever used a “cheater plug”?
  • Yes
  • No
EC IEEE 1584 Global MAY2013.pdf [129.02 KiB]
Downloaded 610 times
Author:  stevenal [ Mon Jan 28, 2013 8:33 am ]
Passed around in the lab at college to prevent short circuiting the reference clip on the o-scope.
Author:  tim8282 [ Mon Jan 28, 2013 10:46 am ]
I think it would be a good idea to clarify the question as to saying "used a cheater plug incorrectly". I touched on it in last weeks discussion but when used properly (remove outlet cover screw and fasten metal tab) on an outlet which has a metal box and is supplied by grounded conduit I believe they are safe.
As for me, I mainly used them when working for a test lab to perform leakage current measurements where we needed to intentionally lift the ground.
http://www.phpbb.com/
