Arc Flash Forum
need help on ARC MATERIAL
https://brainfiller.com/arcflashforum/viewtopic.php?f=5&t=5237
Page 1 of 1
Author:  sio8 [ Tue Jan 07, 2020 8:15 pm ]
Post subject:  need help on ARC MATERIAL
Hi guys, i am new to this forum,
i am searching for the ARC material in BLUE color, the common one is green color, do you guys know any supplier or source for recommendation?
the material will be one kind of powder which can be mixed with PC resin to make arc proof lens,
thanks in advance,
Author:  NicDukes97063 [ Mon Jan 13, 2020 1:41 pm ]
Post subject:  Re: need help on ARC MATERIAL
We have had people recommend:
You might try there.
Good luck!
Author:  sio8 [ Tue Jan 14, 2020 5:37 pm ]
Good luck!
i am really thankful for your reply, but it seems the link to other website is not allowed here, it was removed when i logged in,
would you please just let me know some keywords so that i can search on internet to find that supplier, thanks :)
Author:  wbd [ Wed Jan 15, 2020 5:47 am ]
links to commercial websites and personal contact info can be sent via the PM function. Try contacting the poster using that function.
Author:  Jim Phillips (brainfiller) [ Thu Jan 16, 2020 10:49 am ]
Good luck!
Due to past spam postings by people that have just registered for the forum, the PM function does not work for new users until they have made 3 posts. Just respond to this post and it will be your 3rd and then you can use the PM.
Author:  sio8 [ Thu Jan 16, 2020 6:43 pm ]
Good luck!
Due to past spam posting, the PM function does not work for new users until they have made 3 posts. Just respond to this post and it will be your 3rd and then you can use the PM.
thank you for the response to my question, it helps a lot, :D
http://www.phpbb.com/
