Arc Flash Forum
VCB Electrode Configuration?
https://brainfiller.com/arcflashforum/viewtopic.php?f=8&t=5653
Page 1 of 1
Author:  makoester1 [ Tue Jan 10, 2023 6:03 am ]
Post subject:  VCB Electrode Configuration?
What electrode configuration would you utilize? I believe it is fairly straight forward for the bus section where the cables will connect (VCB). Although this is not a likely occurrence, is it possible that an HCB configuration could be valid if the bus insulation failed or the bus was uninsulated?
Thanks for your input.
http://www.phpbb.com/
