It is currently Thu Oct 29, 2026 3:41 pm
 Post subject: Arc Flash Policy Template
PostPosted: Fri Dec 24, 2010 5:13 am
Does anyone have a template for an Arc Flash safety policy for a wastewater treatment facility.
PostPosted: Mon Dec 27, 2010 6:01 am
IMHO, there should be no difference in safety policies based on the type of facility. 70E lays the foundation for all AF safety. Working safely on a 600 amp disconnect in a WWTP is the same as working safely on a 600 amp disconnect in a high rise apartment building.
PostPosted: Mon Dec 27, 2010 9:10 am
NFPA 70E has several Annex's in the document that may help you:
Annex E - Electrical Safety Program
Annex F - Hazard/Risk Evaluation Procedure
etc.
