It is currently Mon Oct 12, 2026 3:22 pm
 Post subject: This is why you should avoid installing panels in vaults
PostPosted: Fri Apr 05, 2019 5:06 am
This panel is only 4 years old. It was installed in an underground vault. The sump pump failed and it was awhile before it was discovered.
