| Author |
Message |
zrjohnso
Post subject: PPE within Substations Posted: Mon Jun 30, 2008 12:33 pm |
Joined: Mon Jun 30, 2008 12:07 pm Posts: 13 Location: Charlotte, NC
| Top |
haze10
Post subject: Posted: Mon Jun 30, 2008 2:01 pm |
Joined: Thu Jan 10, 2008 8:49 pm Posts: 520 Location: New England
| Top |
jghrist
Post subject: Posted: Mon Jun 30, 2008 6:24 pm |
Joined: Wed Jun 04, 2008 9:17 am Posts: 428 Location: Spartanburg, South Carolina
| Top |
zrjohnso
Post subject: Posted: Tue Jul 01, 2008 6:59 am |
| Top |
haze10
Post subject: Posted: Tue Jul 01, 2008 5:40 pm |
| Top |
wbd
Post subject: Posted: Mon Aug 04, 2008 11:58 am |
| Plasma Level |
Joined: Wed May 07, 2008 5:00 pm Posts: 881 Location: Rutland, VT
_________________ Barry Donovan, P.E. www.workplacesafetysolutions.com
| Top |
DanM
Post subject: Posted: Tue Aug 05, 2008 5:08 am |
| Top |
wbd
Post subject: Posted: Thu Sep 18, 2008 7:57 am |
| Plasma Level |
| Top |
LHall
Post subject: Posted: Wed Oct 01, 2008 7:29 pm |
| Top |
acobb
Post subject: Posted: Thu Oct 02, 2008 7:54 am |
Joined: Sun Dec 23, 2007 1:44 pm Posts: 348 Location: Charlotte, NC
PPE in Substations
I am seeing PPE levels all across the board! Talked with one municipal utility that is requiring 8 cal PPE just to enter an outdoor substation. When I questioned the logic, given that in this situation the lowest live parts were 9 feet or more above the ground and anything lower than that was enclosed and 5 to 6 feet above ground level, the response I got was "just because we are concerned about liability". I have seen the results when substation breakers fail violently but have yet to see one that ruptures the enclosure. Seen some pretty badly deformed cabinets and buckled steel support legs as well! Most likely it might blow the bushings, and if it did my biggest concern would be the shrapnel from the porcelain which is as sharp as a razor, but I don't have a PPE chart for porcelain. So far with the work we have done we are not encountering major problems on the high voltage portion of the systems. But also before we started with the calcs, we already knew that arc flash had not been a problem with our clients in the past and we think the calcs show why that is the case. With respect to PPE for the people mowing and if it comes down strictly to liability, then we must ask if they are qualified to be there to start with. We gravel it and keep the grass and weeds killed so we do not have to mow. I would be concerned about personnel and the equipment if they are mowing that close to it. I do recall a case years back when a guy mowing caught a voltage regulator ground and broke it. He then touched the floating 7200 volt ground and did not make it out alive! Gravel is a better choice and roundup is probably cheaper than mower gas these days! As far as painters go, I would not allow it to happen on energized equipment anyway, and then you are dealing with approach distances for qualified personnel, unless it is only touch up at ground level. Hope it helps, Alan
| Top |
Zog
Post subject: Posted: Thu Oct 02, 2008 9:53 am |
Joined: Mon Jun 02, 2008 11:58 am Posts: 1103 Location: Charlotte, NC
| Top |
Zog
Post subject: Posted: Thu Oct 02, 2008 9:55 am |
acobb wrote: Most likely it might blow the bushings, and if it did my biggest concern would be the shrapnel from the porcelain which is as sharp as a razor, but I don't have a PPE chart for porcelain.
Easy, just wear this
| Attachments: |
| Top |
acobb
Post subject: Posted: Thu Oct 02, 2008 1:03 pm |
Move the fence
If the fence is that close to the equipment it probably should have already been moved! I was about to add that my porcelain PPE would probably include a layer of Kevlar. Thanks, Alan
| Top |
haze10
Post subject: Posted: Thu Oct 02, 2008 4:00 pm |
| Top |
acobb
Post subject: Posted: Thu Oct 02, 2008 6:40 pm |
Gotta be real!
| Top |
lkincer
Post subject: Posted: Thu Mar 19, 2009 1:01 pm |
zrjohnso wrote: I am performing arc flash calculations on substation equipment for 4kV, 12kV, and 25kV systems. Does anyone have an answer/opinion on wearing appropriate arc flash for opening circuit breaker doors to verify equipment name plates or to view relay settings on either electromechanical or electronic relays? Further, what about viewing AC panel circuit breakers for station service, or checking/changing Voltage Regulator settings?
| Top |
acobb
Post subject: Posted: Thu Mar 19, 2009 7:12 pm |
| Top |
stevenal
Post subject: Posted: Fri Mar 20, 2009 3:38 pm |
| Top |
Page 1 of 1
[ 18 posts ] |
