It is currently Sat May 30, 2026 1:35 pm
 Post subject: Adding devices to library in EasyPower
PostPosted: Thu May 28, 2026 10:38 am
I suppose some of the info I need is EasyPower specific, and some more broadly applicable to all AFS software. So a widely used circuit breaker is not in the EP device library (Square D PowerPact JGL36200). It seems the quickest way to solve this is to add the device to my local device library, but there are two issues:
1) I haven't been able to locate that info from Schneider/Square D's websites, and
2) EasyPower's library gives me an error "The Min Clearing curve in style XXXXX, frame xxxxx requires at least two points....", and when I insert values for Min Clearing curve, it tells me there are "Missing Pickup values".
Anyone here have experience adding devices to the library in EasyPower, and/or anyone here know where to find this data from the manufacturer? Thank you!
