It is currently Fri Nov 06, 2026 12:20 am
 Post subject: Calculator - Spanish
PostPosted: Fri Mar 14, 2014 6:13 am
Anyone have an unlocked (Or Spanish) version of the old NFPA 70E Excel arc calculator? I need to change the verbage to spanish for a presentation but the sheet is password protected on the cells that have the wording so you can only change the data for input.
PostPosted: Mon Mar 17, 2014 9:44 am
Hi Zog, if you want i could help you just sendme the excel file and ill doit for you
mauricioville@gmail.com
PostPosted: Mon Mar 31, 2014 5:14 am
You may also provide a set of definitions of the terms in Spanish. Since the standards are in English it may be more helpfull if the calculator stays in English. Terms in Spanish may vary region to region, or country to country as well.
