It is currently Sun Nov 15, 2026 7:50 pm
 Post subject: Arc Flash in High Altitude Applications
PostPosted: Fri Feb 19, 2010 9:14 am
What impact would lower rH and quite high altitudes have on hazard distances and arc flash hazards in general? We are working on a 23 kV transmission system at 5000 meters in the Andes Mountains.
PostPosted: Fri Feb 19, 2010 10:20 am
At higher altitudes the voltage stress will definetly cause the air to electrically break down sooner at a lower voltage level(approx.2-10%).(google for these actual correction values/formula) :)
PostPosted: Fri Feb 19, 2010 11:39 am
Thanks for the info. I have been Googling around but an having trouble finding definitive info as to how much impact it might have. Will keep looking.
PostPosted: Fri Feb 19, 2010 2:14 pm
Try this link:
http://ieeexplore.ieee.org/Xplore/login.jsp?url=http%3A%2F%2Fieeexplore.ieee.org%2Fiel5%2F6616%2F17682%2F00816711.pdf%3Farnumber%3D816711&authDecision=-203
Study of the breakdown voltage of the air in high altitudes, applying lightning impulses (1.2/50 μs) under conditions of controlled humidity and temperature
Note:You will need to be a I.E.E.E. member
I will try to get the sphere gap graphs for you.
PostPosted: Fri Feb 19, 2010 4:09 pm
Here is a link to these spark gap correction factors for humidity and altitude(it is the 4th one down on this list).Enjoy (: )
http://www.google.ca/search?sourceid=navclient&ie=UTF-8&rlz=1T4RNWE_enCA309CA309&q=sphere+gaps+correction+factors
