| Author |
Message |
Power Engineer
Post subject: Arc Flash Article Posted: Thu Sep 06, 2007 12:23 pm |
Joined: Mon Aug 20, 2007 1:31 pm Posts: 2 Location: New York
Just thought I would give you all a heads up on a terrific article in the August issue of the NEC Digest. The article is the cover story - "How to Perform an Arc Flash Study in 12 Steps". The author is Jim Phillips.
I believe it does an excellent job of explianing the process. This looks like this is the fisrt of three articles on this subject.
| Top |
John Shriver
Post subject: Posted: Thu Sep 13, 2007 5:58 am |
It's kind of a long URL/link but I found the article on the NEC Digest's website.
[url="http://www.nfpa.org/itemDetail.asp?categoryID=1426&itemID=35647&URL=Publications/necdigest/necdigest%20in%20Print/Current%20issue/Features"]http://www.nfpa.org/itemDetail.asp?categoryID=1426&itemID=35647&URL=Publications/necdigest/necdigest%20in%20Print/Current%20issue/Features[/url]
| Top |
Jim Phillips (brainfiller)
Post subject: Posted: Tue Jun 24, 2008 8:59 am |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
John,
It looks like the NFPA link no longer goes to the article. Here are the links to the three parts of the article "How to Perform an Arc Flash Study in 12 Steps.
[url="http://www.brainfiller.com/documents/ArcFlashJimPhillipsPart1.pdf"]Part 1[/url]
[url="http://www.brainfiller.com/documents/ArcFlashJimPhillipsPart2.pdf"]Part 2[/url]
[url="http://www.brainfiller.com/documents/ArcFlashJimPhillipsPart3.pdf"]Part 3[/url]
_________________ Jim Phillips, P.E. Brainfiller.com
| Top |
Bombo
Post subject: Posted: Thu Jul 10, 2008 11:29 am |
Joined: Thu Jun 12, 2008 2:07 pm Posts: 20 Location: SLC
Time current curveHey Brainfiller, Hi Jim,
I was reading your "How to Perform an Arc Flash" paper, it is very informative.  I was wondering if you have a more in depth explanation of the Time-Current Curve somewhere that I can look at? Maybe one with examples of reading it...
| Top |
haze10
Post subject: Posted: Fri Jul 11, 2008 9:24 pm |
Joined: Thu Jan 10, 2008 8:49 pm Posts: 520 Location: New England
| Top |
Post subject: Posted: Mon Jul 14, 2008 6:51 am |
| Plasma Level |
Hi Bombo,
The IEEE Red and Buff books have some good info if you have access to a technical library. Also if you go to a short video clip: [url="http://www.brainfiller.com/documents/Coordination2MediumBandwidth_001.wmv"]instantaneous coordination[/url] it might help a bit.
I'll be in touch off line with a few more suggestions.
| Top |
Zog
Post subject: Posted: Mon Jul 14, 2008 7:24 am |
Joined: Mon Jun 02, 2008 11:58 am Posts: 1103 Location: Charlotte, NC
Bombo wrote: Hey Brainfiller, Hi Jim, I was reading your "How to Perform an Arc Flash" paper, it is very informative.  I was wondering if you have a more in depth explanation of the Time-Current Curve somewhere that I can look at? Maybe one with examples of reading it... Thanks,
Try this animated slide
| Attachments: |
| Top |
Bombo
Post subject: Posted: Mon Jul 14, 2008 8:12 am |
Time current curvesThanks to all of you guys. It all helps a lot!
| Top |
Page 1 of 1
[ 8 posts ] |
