It is currently Fri Nov 06, 2026 11:25 pm
 Post subject: Short Circuit Rating of Equipment less than 50Vdc
PostPosted: Fri Sep 21, 2012 5:51 am
I have been asked by my customer how does the NEC apply to a -48VDC system (Gov't office). The question relates to short-circuit rating of equipment feed by a -48VDC battery back-up system.
If I remeber correctly the NEC excludes low voltage systems (<72V), which it does not governn, but I can not find this within teh NEC code book.
Can anyone asist?
Jack
PostPosted: Mon Sep 24, 2012 2:15 pm
Effectively, the NEC covers all voltages. It does have a section on power limited systems which has limitations on voltage (usually <30VDC) and current.
It is only NFPA70E that has a defined cut off.
