It is currently Fri Nov 06, 2026 11:50 pm
 Post subject: Certificates of completion for 70E
PostPosted: Mon Sep 24, 2012 9:56 am
I teach the 70E classes at the IBEW JATC in San Bernardino CA I was wondering if there is a card or stickers that can be given once the student successfully completes the class?
PostPosted: Mon Oct 01, 2012 7:15 am
Laura... I just go to Office Depot and buy certificate stock. Design the certificate in Microsoft Publisher and print them out. My certificates simply state " John Doe has successfully completed an 8 hour course on NFPA 70E 2012". I also use business card stock to print wallet cards and laminate them. The wallet cards are essential for electricians that move amongst different facilities.
PostPosted: Sun Oct 07, 2012 6:55 pm
Thank you for your input. Laminated wallet cards will work perfectly thank you
