It is currently Tue Nov 24, 2026 8:00 am
 Post subject: SKM Arc Flash Calculations
PostPosted: Fri Jun 21, 2019 8:01 am
Hello! I'm wondering if it makes more sense to use actual VS SKM default values when you are looking at this graph (attached). Would it be better to use the actual trip value or the default SKM gives you? I feel like it would be better to use the actual trip value, but I'm not 100% sure.
