It is currently Sun Nov 01, 2026 11:48 pm
 Post subject: Dynamometer Modeling in SKM
PostPosted: Tue Nov 27, 2012 10:34 am
Good morning all,
I want to model a Dynamometer in SKM and there are many unknowns in this project for the moment. My strategy is to divide and conquer.
Currently the dynamometer will be fed by an upstream feeder circuit breaker (FCB-02) which is attached to a VFD. FCB-02 is fed by an isolation transformer which is fed by an upstream breaker (FCB-01).
Questions:
In the Dynamometer Manufacturer Sheet it states 450Hp ABS & Rated 400Hp. What is ABS stand for?
I will post most questions once this thread developes.
Thank you all.
PostPosted: Sat Dec 08, 2012 8:25 am
Usually ABSolute aka stall.
PostPosted: Mon Dec 17, 2012 12:56 pm
Thank you!
