| Author |
Message |
jsoar
Post subject: What are some ways to lower the Incident Energy for a Panel? Posted: Thu Sep 04, 2025 12:51 pm |
| Attachments: |
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 1:42 pm |
| Arc Level |
_________________ Retired but I might visit once in awhile
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 1:51 pm |
| Arc Level |
| Top |
jsoar
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 2:02 pm |
Hey, I used a Fused disconnect with FRS-R 175A. I was able to bring it down to 6.01. The customer wants to bring it under 4 cals if possible. I did play around and add an adjustable trip breaker. that did bring it under 4.
| Attachments: |
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 2:16 pm |
| Arc Level |
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 2:25 pm |
| Arc Level |
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 2:32 pm |
| Arc Level |
Run the report and look at your clearing time. I bet you are more than 2 seconds on the MCB. Also, I am having a hard time re-creating your model and getting 3000A of AFC with a 45 kva transformer at that %Z. I can only get like 3400A of bolted fault current. When I overlay the curves, you are barely in the instantaneous range of the breaker, if you even are. Attachment:
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 2:33 pm |
| Arc Level |
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Thu Sep 04, 2025 2:39 pm |
| Arc Level |
My AFC is much lower than yours. Same transformer, same cables. Not sure why. Mine times out at 2 seconds because I'm not in the instantaneous region of the MCB curve. Attachment:
| Top |
bbaumer
Post subject: Re: What are some ways to lower the Incident Energy for a Pa Posted: Fri Sep 05, 2025 1:57 am |
| Arc Level |
| Top |
Page 1 of 1
[ 10 posts ] |
