| Author |
Message |
wbd
Post subject: Bus Duct Labeling Posted: Wed Mar 30, 2011 4:35 am |
| Plasma Level |
Joined: Wed May 07, 2008 5:00 pm Posts: 881 Location: Rutland, VT
I searched the labeling forum and didn't see this address but I apologize if I missed it someplace.
What is everyone doing for labeling on a bus duct? Labeling entire bus with the worst case AFH? Prominently marking bus where AFH changes and labeling each side accordingly?
_________________ Barry Donovan, P.E. www.workplacesafetysolutions.com
| Top |
jghrist
Post subject: Posted: Wed Mar 30, 2011 6:48 am |
Joined: Wed Jun 04, 2008 9:17 am Posts: 428 Location: Spartanburg, South Carolina
If it is not Quote: likely to require examination, adjustment, servicing, or maintenance while energized (NEC 110.16) then I don't see why it has to be labeled.
| Top |
wbd
Post subject: Posted: Wed Mar 30, 2011 6:58 am |
| Plasma Level |
Thank you but I was thinking of where there are bus duct plug ins and the possibly of disconnects being plugged in to the bus duct at various locations along the bust duct.
| Top |
JBD
Post subject: Posted: Wed Mar 30, 2011 7:26 am |
Joined: Mon Jan 18, 2010 11:35 am Posts: 617 Location: Wisconsin
I see a some labeling just on the incoming section. But, it seems most people label every 20-30 feet or so.
I have no customers that label busway with multiple incident energy values.
Our policy is to recommend the use the worst case for the run.
| Top |
cbauer
Post subject: Posted: Wed Mar 30, 2011 11:53 am |
Joined: Mon Mar 29, 2010 11:52 am Posts: 110 Location: Yankton SD/ Lead SD
We label every section of duct, both sides, with the worst case scenario IE.
| Top |
dinkelja
Post subject: Re: Bus Duct Labeling Posted: Thu Jul 24, 2014 10:02 am |
Anyone have new thoughts on this query?
| Top |
wbd
Post subject: Re: Bus Duct Labeling Posted: Sun Jul 27, 2014 6:59 am |
| Plasma Level |
It has been awhile since this post and here is what I am doing:
1. Determine the worst case arc flash hazard on the bus duct which is usually at the end of the bus duct run. 2. Discuss with the client on what their preference is for labeling. This has been varied: *one label at beginning junction box *labels on each side alternating every X ft *labels on beginning junction box and at the end of the bus duct.
| Top |
Page 1 of 1
[ 7 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
