It is currently Fri Sep 18, 2026 3:58 am
 Post subject: Electrocution leads to OSHA inspection, $189K fine
PostPosted: Thu Oct 04, 2012 4:02 am
An employee was electrocuted while working to restore power to a pumping station. OSHA heard about the fatality and investigated. The investigation determined the employee came into contact with energized electrical parts. The electrocution occurred in April.
[url='http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=NEWS_RELEASES&p_id=23064']OSHA says Halcon Resources Corp. of Electra, Texas, failed to adequately training employees on the hazards of electrical repairs near energized equipment[/url].
The company now faces two willful and seven serious OSHA fines. The serious citations are for failing to:
  • provide training on safe work practices, and
  • provide electrical protective equipment, such as gloves, for employees performing maintenance work.
The serious violations include failure to:
  • provide specific lockout/tagout procedures
  • ensure energy sources of electrical equipment are locked out before performing maintenance
  • test electrical personal protective equipment
  • ensure only qualified personnel perform testing and maintenance on electrical equipment.
The proposed penalties total $189,000.
The company has 15 business days to contest the fines.
Halcon Resources is a Houston-based oil and gas servicing company and does business as WG Operating.
Image[url='http://www.addtoany.com/share_save?linkurl=http%3A%2F%2Fwww.safetynewsalert.com%2Felectrocution-leads-to-osha-inspection-189k-fine%2F&linkname=Electrocution%20leads%20to%20OSHA%20inspection%2C%20%24189K%20fine']Image[/url]
[url="http://www.safetynewsalert.com/electrocution-leads-to-osha-inspection-189k-fine/"]Continue reading...[/url]
Arc Flash Forum News Feed
