It is currently Wed Oct 28, 2026 2:11 am
 Post subject: GE Introduces Light and Pressure Arc Flash Detection System
PostPosted: Wed Feb 13, 2013 8:29 am
GE Announces The Multilin A60 Arc Flash System
The Multilin A60 uses GE's light and pressure wave detection technology to detect and initiate a trip signal, in the event of an arc flash condition. By quickly initiating the trip signal, the Multilin A60 helps minimize equipment damage and reduce the costs associated with unplanned downtime and lost production.
Designed for medium voltage switchgear and motor control center applications, the Multilin A60 is a protection relay independent, stand-alone device that can be used in new or existing installations for continuous monitoring and fast detection of an arc flash event. Its design includes five arc flash sensors for optimal coverage and its scalability allows multiple Multilin A60 devices to be connected, delivering increased fault isolation for reduced equipment damage. The Multilin A60 simplifies installation, commissioning and maintenance with sensor auto-calibration, eliminating the need for CT connections or setup software, reducing total operation and maintenance costs.
The Multilin A60 comes equipped with a self-test feature that monitors the health of the sensors, the full length of the fiber cables, and the unit itself, eliminating the need for periodic testing, additional test equipment, and ensuring reliable operation when needed
most.
[url='http://www.gedigitalenergy.com/press/A60/index.htm']Click here for more information[/url] about GE's Multilin A60 Arc Flash System
[url='http://www.learnlabeling.com/4.php']Image[/url]
[url="http://feedproxy.google.com/~r/Nfpa70e/~3/84vX8RLkAo4/ge-introduces-light-and-pressure-arc_13.html"]Continue reading...[/url]
Arc Flash Forum News Feed
