It is currently Fri Oct 30, 2026 5:49 am
 Post subject: Electrical Safety Analyzer targets on-the-go technicians.
PostPosted: Tue Apr 15, 2014 6:55 am
Built with rubberized case for durability, Model ESA609 integrates all functions needed to test medical devices when patient lead testing is not required, including: line (mains) voltage, ground wire resistance, equipment current, leakage current, and point-to-point tests. Portable unit tests to ANSI/AAMI ES1, NFPA-99, and parts of IEC62353 and IEC60601-1. With heavy-duty switches, users can
change polarity and configuration of neutral connection between open and closed.
This story is related to the following:
[url='http://news.thomasnet.com/news/sensors-monitors-transducers']Sensors, Monitors and Transducers[/url] Sponsored by: [url='http://news.thomasnet.com/redir.html?lnty=rssad&spclid=10003&prid=20025208&cat=2399&goto=http%3A%2F%2Fwww.beisensors.com%2Fprogrammable-encoder-omnicoder.html']BEI Sensors (BEI Industrial Encoders) - Cat Sponsor Jan 2014[/url]
[url='http://news.thomasnet.com/news/test-measuring-instruments']Test and Measuring Instruments[/url]
[url='http://news.thomasnet.com/news/safety-security-equipment']Safety and Security Equipment[/url]
Search for suppliers of: [url='http://www.thomasnet.com/products/electrical-safety-testers-95928438-1.html']Electrical Safety Testers[/url] | [url='http://www.thomasnet.com/products/electronic-usage-analyzers-130-1.html']Electronic Usage Analyzers[/url] | [url='http://www.thomasnet.com/products/electrical-safety-specialties-25340688-1.html']Electrical Safety Specialties[/url]
[url="http://news.thomasnet.com/fullstory/Electrical-Safety-Analyzer-targets-on-the-go-technicians-20025208"]Continue reading...[/url]
Arc Flash Forum News Feed
