It is currently Wed Oct 14, 2026 2:07 pm
 Post subject: Reactive power explanation
PostPosted: Wed May 09, 2012 5:27 am
The concept of reactive power in AC circuits is fundamental for Electrical Engineering.
Here is an explanation:
http://engineering.electrical-equipment.org/energy-efficiency-kvar/reactive-power.html
PostPosted: Wed May 09, 2012 2:46 pm
Apparent power is ordering a beer. Real power is what you want...the liquid. Reactive power is the foam, the stuff that you have to take when you order the beer and it takes up space but leaves you with no satisfaction whatsoever.
PostPosted: Sun May 13, 2012 9:29 am
Does it matter if it is a lager or stout? :D
PostPosted: Mon May 14, 2012 5:22 am
Yes, stouts are not supposed to have a head, they should have a lower pressure (Less bubbles) and higher nitrogen to CO2 mix (Smaller bubbles) than a lager so stouts should be at near 1.0 PF.
