It is currently Mon Oct 19, 2026 5:23 am
 Post subject: New Arc Suppression Device
PostPosted: Sun Jan 27, 2013 4:24 pm
[ATTACH=full]286[/ATTACH]
Someone sent this to me a while ago - the original source is unknown. I believe it is a new arc flash suppression receptacle. However it might be in direct conflict with GFCI requirements around wet locations ;)
ArcFlashHazard Littlefuse reduced.pdf [270.9 KiB]
Downloaded 643 times
PostPosted: Sun Jan 27, 2013 6:59 pm
Do you have a patent on this amazing new product? :)
PostPosted: Mon Jan 28, 2013 2:36 pm
Reminds of an old Three Stooges program. The guys are doing a plumbing job when they find the problem to be wires in the pipes. The wires are surprisingly springy, but eventually they are removed and the pipes are connected. Light bulbs fill with water and burst. N'yuk n'yuk n'yuk!
Here it is:
[media=youtube]CsKFhOw-PXw[/media]
