It is currently Fri Oct 30, 2026 11:09 am
Have you seen the First Draft (ROP) of the 2015 NFPA 70E?
Yes 62%  62%  [ 18 ]
No 38%  38%  [ 11 ]
Total votes : 29
 Post subject: 2015 NFPA 70E First Draft (previously Report on Proposals (ROP))
PostPosted: Sun Mar 17, 2013 3:25 pm
Have you seen the First Draft (ROP) of the 2015 Edition of NFPA 70E?
  • Yes
  • No
You can find it at this thead:
[url='http://arcflashforum.brainfiller.com/threads/2671/'][2015 NFPA 70E First Draft (previously Report on Proposals - ROP)][/url]
PostPosted: Mon Mar 18, 2013 7:40 am
I was going to vote "no" until I saw the link then changed to "yes". Although once again this will be quite a bit of information to absorb. - Thanks!
