It is currently Thu Oct 15, 2026 8:59 am
Have you or someone you know ever used a "cheater plug"?
Yes 91%  91%  [ 21 ]
No 9%  9%  [ 2 ]
Total votes : 23
 Post subject: Cheater Plug - Grounding
PostPosted: Sun Jan 27, 2013 3:07 pm
Last week’s question about cutting the ground prong evolved into a discussion about what was planned as this week’s question regarding “cheater plugs� These are the plugs that “convert� a three prong input into a two prong output.
This week’s question: Have you or anyone you know ever used a “cheater plug�?
  • Yes
  • No
EC IEEE 1584 Global MAY2013.pdf [129.02 KiB]
Downloaded 610 times
PostPosted: Mon Jan 28, 2013 8:33 am
Passed around in the lab at college to prevent short circuiting the reference clip on the o-scope.
PostPosted: Mon Jan 28, 2013 10:46 am
I think it would be a good idea to clarify the question as to saying "used a cheater plug incorrectly". I touched on it in last weeks discussion but when used properly (remove outlet cover screw and fasten metal tab) on an outlet which has a metal box and is supplied by grounded conduit I believe they are safe.
As for me, I mainly used them when working for a test lab to perform leakage current measurements where we needed to intentionally lift the ground.
