It is currently Wed Oct 28, 2026 5:22 pm
Which of the following arc flash software have you / your consultants used? Select all that apply
ArcPro 5%  5%  [ 5 ]
ArcAD 5%  5%  [ 5 ]
EasyPower 25%  25%  [ 24 ]
ETAP 18%  18%  [ 17 ]
Milsoft 6%  6%  [ 6 ]
Power Analytics (EDSA) 8%  8%  [ 8 ]
SKM 28%  28%  [ 27 ]
Other (please tell us) 5%  5%  [ 5 ]
Total votes : 97
 Post subject: What Arc Flash Software Do You Use?
PostPosted: Sun Mar 10, 2013 4:00 pm
Which of the following arc flash software have you or your consultants used?
SELECT ALL THAT APPLY
  • ArcPro
  • ArcAD
  • EasyPower
  • ETAP
  • Milsoft
  • Power Analytics (EDSA)
  • SKM
  • Other (please tell us)
PostPosted: Mon Mar 11, 2013 6:53 am
SynerGEE
PostPosted: Mon Mar 11, 2013 7:00 am
I am curious.
Is there a particular reason you have chosen the software you use over the others that are available?
PostPosted: Mon Mar 11, 2013 8:50 am
Arcad is really user friendly and data entry is intuitive and very accesible. One advantage is their tech support really help me to understand a couple of questions generated during the process. Pricing is very affordable too.
PostPosted: Tue Mar 12, 2013 9:39 am
IEEE Excel spreadsheet.
PostPosted: Tue Mar 12, 2013 4:29 pm
I have been using EasyPower since around 1998. I had looked at EDSA, ETAP and SKM and at that time it seemed the most user friendly. I even took a trip to see Conrad St. Pierre and see it in use by a well known electrical engineer. So the familiarity plus excellent tech support keeps me using it.
PostPosted: Thu Mar 14, 2013 8:03 am
We use two software packages. The 1st is "FlashTrack" for the data collection. It is easy to use and a qualified worker can quickly collect all the data needed for the engineer it do the analysis using (in our case) SKM.
Note: FlashTrack is not for doing calculations, it was designed for the qualified worker to capture the data needed to model the system.[ATTACH=full]293[/ATTACH]
Bryan Rupert
[url='http://facilityresults.com/W1/']Facility Results[/url]
