It is currently Tue Oct 20, 2026 1:46 pm
Have you ever been burned? (from any source)
Yes – First Degree 26%  26%  [ 12 ]
Yes – Second Degree 41%  41%  [ 19 ]
Yes – Third Degree 2%  2%  [ 1 ]
No 30%  30%  [ 14 ]
Total votes : 46
 Post subject: Have you ever been burned (from any source)
PostPosted: Sun Oct 06, 2019 2:09 pm
PPE and Arc Flash Studies are about protecting the worker from burn injury as a result of an arc flash.
This week’s question is about burn injury from ANY source. Arc flash, fire, hot surface etc.
Yes – First Degree
Yes – Second Degree
Yes – Third Degree
No
(Stories are encouraged!)
 Post subject: Re: Have you ever been burned (from any source)
PostPosted: Mon Oct 07, 2019 7:17 am
Soldering iron - first degree and second degree
Sunburn - first degree and borderline second degree
Campfire - both second degree and first degree
PostPosted: Fri Oct 11, 2019 6:39 am
Gas stove (probably the first bright memory from childhood)
Boiled water
СаС2 (aka Carbide) water mixture explosion (burnt eyebrows, eyelashes and fingers)
Electric heater
Campfire
Sunburn
Contrary to widely spread and arc flash industry accepted concept of 1.2 cal/cm2 threshold incident energy to 2nd degree burn, I strongly believe that the scope and severity of burn has nothing to do with the amount of incident energy but with the rate the energy has been delivered.
Michael Furtak, C.E.T.
http://arcadvisor.com
