It is currently Fri Oct 16, 2026 7:49 am
Does your company/client(s) have power factor correction capacitors?
Yes - Low Voltage - 1,000 volts and less 49%  49%  [ 22 ]
Yes - Medium Voltage - above 1000 volts 40%  40%  [ 18 ]
No 11%  11%  [ 5 ]
Total votes : 45
 Post subject: Power Factor Correction Capacitors
PostPosted: Sun Nov 03, 2019 3:53 pm
Capacitors can be a source of an electrical hazard.
This week’s question is about power factor correction capacitors. Here is the question:
No
Select up to 2 responses
