It is currently Fri Oct 23, 2026 8:41 am
Which method(s) do you/clients use for PPE selection?
IEEE 1584 42%  42%  [ 28 ]
NFPA 70E PPE Category Table 21%  21%  [ 14 ]
NESC Tables 12%  12%  [ 8 ]
Arc Pro 17%  17%  [ 11 ]
DGUV-I 203-078 5%  5%  [ 3 ]
Other Methods (please describe) 2%  2%  [ 1 ]
Not sure – company/consultant developed 2%  2%  [ 1 ]
Total votes : 66
 Post subject: PPE Selection - What Method Do You/Clients Use?
PostPosted: Sun Dec 01, 2019 3:23 pm
There are several methods available for determining arc rated clothing and PPE. Some are better known or more common than others. Here is this week’s question.
Which method(s) do you/clients use for PPE selection? - SELECT ALL THAT APPLY
• IEEE 1584 – IEEE Guide for Performing Arc-Flash Hazard Calculations
• NFPA 70E Table 130.7(C)(15)(a) and (b) PPE Category Tables
• NESC Tables 410-1, 410-2, 410-3 – Clothing and Clothing Systems
• Arc Pro
• DGUV-I 203-078 - Thermal hazards from electric fault arc Guide to the selection of personal protective equipment for electrical work
• Other Methods (please describe)
• Not sure – company/consultant developed
