It is currently Sun Nov 15, 2026 9:10 pm
 Post subject: Soft Starters
PostPosted: Tue Sep 21, 2010 1:00 pm
How do reduced voltage soft starters effect short circuit currents? How are these even modeled in SKM (software I am using)?
Thanks in advance!
PostPosted: Tue Sep 28, 2010 6:03 am
I don't use SKM but I was advised to model the soft starts as across the line starters. The reason is that once the motor comes up to speed, typically a contactor closes bypasses the "soft start." It then operates as a typical starter.
