It is currently Fri Oct 16, 2026 2:46 pm
 Post subject: Breaker Types
PostPosted: Wed Sep 11, 2024 7:43 am
Is anyone aware of a good resource identifying when to use different breaker types (D, G, J, L, etc.)? We are performing studies for a couple sites where we've located older panels with breakers we cannot verify. If we are lucky they have their ampacity marked but none have their frame/type, or any other information marked. I'm hoping to provide the team with guidance so we can make a reasonable assumption based on the downstream load. For example, use a type D for a motor circuit.
 Post subject: Re: Breaker Types
PostPosted: Wed Oct 30, 2024 3:09 pm
Prior to roughly 1985 breaker information was not often visible without removing the breaker.
Have you tried posting pictures on electrical contractor forums?
I would generally not trust generic breaker trip curves for arc flash incident energy purposes.
