| Author |
Message |
serge.robillard
Post subject: Insulating barriers installed between electrodes Posted: Fri Jan 22, 2021 9:02 am |
Hi everyone.
Thanks!
Serge
| Attachments: |
| Top |
Jim Phillips (brainfiller)
Post subject: Re: Insulating barriers installed between electrodes Posted: Mon Jan 25, 2021 6:43 am |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
How does it affect the incident energy? Remember in the end it is all about making sure the worker is protected from the arc flash should there be energized work (which it to be avoided unless justified based on NFPA 70E) Do the different assumptions result in higher arc ratings for PPE?
| Top |
Page 1 of 1
[ 2 posts ] |
