It is currently Thu Nov 05, 2026 12:13 pm
 Post subject: Required PPE
PostPosted: Thu Jan 15, 2009 2:32 pm
Hello, I am looking for some advice with regards to PPE.
I am a ski lift electrician,
90% of my work is 24V DC controls.
I also work on AC and DC Drives and motors up to 1000HP. the motor work is 99% de-energised testing and cleaning several times a year.
I also work on the 120/220/480 parts of the lifts, including heaters, lights, outlets, main disconnects etc. sometimes these are hot.
I would like some help in determining what i should be wearing on a daily basis and what extra clothing/protection i need for the other parts of my job.
Thanks in advance for yor help.
Keith
PostPosted: Thu Jan 15, 2009 6:46 pm
If you haven't done an analysis then you should use the NFPA task ppe matrix. Being in the ski industry you could wear some heavier clothes and still be comfortable, like Level 2 shirt and pants. You can also find AF coats and winter gear.
PostPosted: Thu Jan 15, 2009 8:19 pm
Remember that there are current and clearing time limitations on the tables, so you have to have some fault current information available from the utility. Then some determination could be made on the applicability of the tables.
PostPosted: Wed Jan 21, 2009 9:48 am
Update....there was a survey conducted at our site and although i do not have a copy of the results, they are in the mail, the highest risk we have is 17cal/cm2.
1. Is class 2 clothing enough protection?
2, I have found a number of sites selling FR clothing but no one sells nomex snow pants? any ideas?
3, I have heard that you can wear "oversized shirts" that will cover your existing clothing, fleece/nylon vest etc, that will provide the correct protection....any thoughts?
Thanks again
PostPosted: Wed Jan 21, 2009 10:12 am
No, HRC clothing is only good for up to 8Cal/CM2, you will need some HRC 3 PPE.
Is there a reason you want nomex? There are plenty of companies that have arc rated snow gear, but not sure about nomex, it would be more expensive anyways. Carhartt has a good line of arc rated cold weather gear, you could start there.
Again, please dont go by what you "heard", you need to get some good 70E training, you need to be trained and qualified to use the PPE, just owning PPE dosent cut it and the advice you are getting from someone is dangerous.
To answer your question, NO You can wear your FR clothing over non melting fabrics but not nylon or other systhetic materials either alone or in blends unless it is proven to be arc rated..
Please get some training before it is too late and you get hurt.
PostPosted: Wed Jan 21, 2009 10:34 am
Thanks for the prompt reply, training is on the way, i am just trying to get a feel for approximate levels of equipment so i can get a rough cost...
..i know, why get a rough cost when you can get the correct answers with training, right.
PostPosted: Wed Jan 21, 2009 1:00 pm
No, I think getting some estimates is a great idea before the training. But there are many other things to do before the training, training is one of the last things to do. You should have your policies ready, EEWP's in effect, etc....
But if you are using nomex for your estimates your estimates will be high. One of the most expensive FR materials there is.
PostPosted: Sat Feb 28, 2009 7:43 pm
I know of a supplier who has winter jackets and bid coveralls pants that are in the 60 cal/cm2 range.
The supplier is Hammel in ON, Canada. I came across these in a recent Electrical Safety Audit.
All you would need for a complete ensemble would be an Arc Flash Hood with at least an ATPV of 60 cal/cm2.
Yes this is a lot of protection, but is a welcome side effect of making the clothing warm for winter wear by layering fabrics.
You may find that some of the fabricators in Canada may have more options for arc rated FR winter clothing than in the USA.
Regards;
Terry Becker, P.Eng.
http://www.esps.ca
