It is currently Sat Oct 24, 2026 4:21 am
 Post subject: Arc-rated bib overall
PostPosted: Fri Jul 24, 2009 1:38 pm
For HRC-2 is it acceptable to use 8cal/cm2 bib overall and an 8cal/cm2 long sleeve shirt?
Not sure if bib overall and shirt are an acceptable combination since it is not shown in NFPA 70E 2009.
PostPosted: Fri Jul 24, 2009 2:04 pm
While ratings are not necessarily additive, I think we could say 8+8= more than 8.
PostPosted: Fri Jul 24, 2009 3:04 pm
As long as the entire body has 8 cal coverage I would say yes.
PostPosted: Sat Jul 25, 2009 9:37 am
I have been in the FR clothing industry for 10 years. I have not seen that combo much for level 2 protection but it would work. I think one reason I haven't seen a bib and shirt for 70E application before is because most bibs have metal buckles on the straps. I do know you can find them with melamine buckles now. Let me know if you need help, http://www.70earcprotection.com.
PostPosted: Mon Jul 27, 2009 8:22 am
Thanks for all the info. I was not sure this combination would be ok since bib overalls are normally loose fitting and hot material may have a chance get into bibs.
PostPosted: Wed Jul 29, 2009 2:07 am
As long as you have full body protection it's okay.
If wearing a shirt and bib overall that would give you the full body as long as you had the head and face protection.
http://www.coverallsale.com/wh-salisbury.htm
PostPosted: Mon Sep 13, 2010 3:41 pm
Any reason you chose to wear the long sleeve shirt with the bib-overalls instead of the 8 cal/cm2 Coveralls?
