It is currently Fri Nov 06, 2026 7:36 pm
 Post subject: Insulating rubber gloves
PostPosted: Sat Oct 24, 2009 9:46 am
In reference to 70E, am I correct to assume that the insulating gloves are not required for simple Arc-Flash PPE, but only when crossing the Prohibited Approach Boundary?
Conversely, when the insulating gloves are coverered in leather protectors, that they are an acceptable part of the Arc-Flash PPE?
What do the Class ratings of rubber insulating gloves signify? Are they simply voltage ratings?
PostPosted: Sat Oct 24, 2009 11:55 am
No, when crossing the RAB
Yep
Yep, the class is the max use voltage, the type is the material they are made of.
