It is currently Wed Nov 04, 2026 8:25 am
 Post subject: Yes!
PostPosted: Thu Mar 24, 2022 11:20 am
I submitted my first public input for the 70E standard. Curious how the process works from this point. Will I receive a response letting me know the committee's thoughts on my input?
 Post subject: Re: Yes!
PostPosted: Thu Mar 24, 2022 11:44 am
Congratulations and thanks for taking part in this very important process!!
You should be notified so you have the opportunity to provide public comment.
Also, you can view the first draft report (link below) to see the proposals and see the balloting results. If you have not created a profile, you will need to do that first.
https://www.nfpa.org/codes-and-standards/all-codes-and-standards/list-of-codes-and-standards/detail?code=70E&tab=nextedition
