It is currently Wed Oct 07, 2026 7:31 am
 Post subject: Wound Rotor Circuit Arc Flash Risk
PostPosted: Thu Aug 13, 2020 11:35 am
An engineer asked my the following question.
Wound rotor induction motors have an external circuit coming from the motor rotor, through slip rings, to a variable resistor bank. The slip ring enclosure and the resistor bank cabinet have an arc flash risk. Is there an established method/standard for calculating the incident energy along the motor secondary circuit? Have you ever run into the situation before?
I do not have any experience with wound rotor induction motors.
Any one cares to enlighten me? Thanks.
