It is currently Fri Oct 16, 2026 8:48 am
 Post subject: Atpv?
PostPosted: Tue Aug 24, 2010 12:32 am
[color="Red"]What is ATPV? EBT?[/color]
PostPosted: Tue Aug 24, 2010 5:16 am
Arc Thermal Performance Value
Energy Break open Threshold
PostPosted: Tue Aug 24, 2010 8:13 pm
Thanks zog, I would like to see some information...
PostPosted: Wed Aug 25, 2010 6:01 am
Arc Thermal Performance Value (ATPV) is defined as the arc incident energy required causing the onset of second-degree burn and is represented in cal/cm2. This rating is the result of a testing procedure (ASTM F-1959) that measures the amount of thermal protection a FR fabric would give a wearer if the person were exposed to an electric arc.
Alternatively the material may have an EBT (Energy Break-open Threshold) rating. EBT is defined as the average of the 5 highest incident energy exposure values below the Stoll curve where the specimen did not exhibit break-open. EBT is reported when ATPV cannot be measured due to FR fabric break open.
PostPosted: Mon Sep 13, 2010 3:20 pm
Great Explanation Zog!
PostPosted: Thu Jun 14, 2012 11:38 am
RezaN wrote:
What is ATPV? EBT?
Here is an article which explains the differences in a little more detail.
http://www.americanchronicle.com/articles/view/130732
