It is currently Tue Oct 20, 2026 6:04 pm
Have you ever been shocked by a DC system? - If yes, what voltage?
Yes 64%  64%  [ 18 ]
No 36%  36%  [ 10 ]
Total votes : 28
 Post subject: DC Electric Shock
PostPosted: Sun May 05, 2013 11:13 am
I have posted several questions about electric shock in the past. Here is a new one based on a recent conversation about the subject.
Have you ever been shocked by a DC system? If the answer is yes, what was the voltage?
  • Yes
  • No
PostPosted: Mon May 06, 2013 6:51 am
Yes, 24 volt.
I was replacing a smashed photo eye; I picked it up twice before I realized I was being shocked. :oops: The equipment operators thought it was hilarious; obviously they had all already touched it too.
PostPosted: Mon May 06, 2013 6:56 am
  • Yes
  • No
544 volts.
PostPosted: Mon May 06, 2013 6:57 am
90, 180, 240, 500 - I used to work on Inverters and DC drives (component level repairs and field service). I can't even count how many times I was shocked off the case of an ungrounded oscilloscope when connected to the armature
Yes, LA class submarine battery, yes the whole string. Voltage classified ;)
PostPosted: Tue May 07, 2013 4:19 am
250VDC
PostPosted: Tue May 07, 2013 8:51 am
125 DC, to the back of the hand, off of the back of a GE protective relay panel door. I grew to hate that dual "door behind door" setup for their gas turbine packages, but it did conserve on the space. Now it would all be replaced by one relay.
