It is currently Thu Aug 20, 2026 8:50 am
 Post subject: Causual effect on separate branch following an arc flash incident
PostPosted: Fri Jan 30, 2009 1:25 pm
Is it likely for an arc flash incident on one branch from primary distribution panel which tripped breaker to blow a fuse in a control panel of a separate branch?
PostPosted: Fri Jan 30, 2009 2:18 pm
The transient that occurred during the incident could feasibly effect anything downstream of the incident, so yes it could.
As in the rapid fluctuations in voltage could cause a fuse with in a control device to draw enough amperage to melt its element.
