It is currently Fri Nov 06, 2026 5:47 am
Will you/client(s) change labeling practices when the 40 cal/cm2 is deleted?
No/Probably not 72%  72%  [ 28 ]
Yes/Probably 26%  26%  [ 10 ]
Doesn’t Apply to Me 3%  3%  [ 1 ]
Total votes : 39
 Post subject: New Labeling Strategy - 40 cal/cm2 deleted?
PostPosted: Sun Mar 12, 2017 2:04 am
This week’s question is a follow up to last week regarding the likely deletion of the 40 cal/cm2 note from the 2018 NFPA 70E.
Many use the signal word DANGER when the incident energy is greater than 40 cal/cm2. A questions was raised by one of our forum members to see if this practice may change with the deletion of the 40 cal/cm2 note.
This week’s question is specifically about labeling.
No/Probably not
Yes/Probably
Doesn’t Apply to Me
