It is currently Sun Aug 23, 2026 10:46 pm
Have you ever used a panelboards local main device to define its arc duration?
Yes 16%  16%  [ 5 ]
No 77%  77%  [ 24 ]
I don't perform studies 6%  6%  [ 2 ]
Total votes : 31
 Post subject: Device that defines the arc duration - Panelboards
PostPosted: Sun Dec 05, 2021 2:38 pm
For panelboards, the next upstream protective device located in a separate enclosure is normally used to define the arc duration. This weeks' question:
Yes
No
 Post subject: Re: Device that defines the arc duration - Panelboards
PostPosted: Mon Dec 06, 2021 8:30 am
What is the correct procedure for evaluating the AFCT for the service panel when there's only one OCPD between it and the utility service entrance? What if it's a 3000A switchboard? Do you know how this should be handled in ETAP?
PostPosted: Tue Dec 28, 2021 10:09 am
I have done this when the incoming wires were complete covered in a lexan shield inside an open cabinet style MCC. I don't believe now that it is correct, but i think realistically, it was ok.
