| Author |
Message |
Nerf
Post subject: Size for Arc flash labeling Posted: Mon Sep 14, 2020 9:27 am |
Hello, good morning, this a exist one standar for regule the size in the arc flash labeling (for example 4" x 6", 6" x 6", etc.)
Excuse me, my english is not perfect.
| Top |
JBD
Post subject: Re: Size for Arc flash labeling Posted: Wed Sep 16, 2020 7:47 am |
Joined: Mon Jan 18, 2010 11:35 am Posts: 617 Location: Wisconsin
There is no standard size.
As Mike said, 4 inches by 6 inches is commonly used.
| Top |
rn70410
Post subject: Re: Size for Arc flash labeling Posted: Mon Sep 21, 2020 2:37 pm |
Hello, my plant's labels are all around 5-1/4" x 4"
| Top |
JJH
Post subject: Re: Size for Arc flash labeling Posted: Tue Sep 22, 2020 4:52 am |
Joined: Wed Jan 28, 2009 2:19 pm Posts: 74 Location: Georgia
I typically use 4" x 6". However, these won't fit on some of the smaller disconnects. In that case, I use a 2 1/4" x 3" label.
| Top |
wilhendrix
Post subject: Re: Size for Arc flash labeling Posted: Tue Sep 22, 2020 6:44 am |
What really matters is that the label font is large enough to be read, and that the labels are put on the device where they are easy to see.
| Top |
Leonard
Post subject: Re: Size for Arc flash labeling Posted: Mon Sep 28, 2020 8:03 am |
Hello Nerf,
as per the others the 4" x 6" is very common. However you have to remember that there is allot of us baby boomers out there in which our eyesite is challenged. Take a look at your work force and see what the average age is of the workers who would be referencing the labels and make your decision from there. I hope that this helps
| Top |
engrick
Post subject: Re: Size for Arc flash labeling Posted: Tue Sep 28, 2021 10:25 am |
Joined: Fri Apr 15, 2011 7:43 am Posts: 179 Location: Colorado
I use 4"x4" with the minimum info - bigger labels may not fit on small equipment
| Top |
sparkie001
Post subject: Re: Size for Arc flash labeling Posted: Fri Jun 09, 2023 10:50 am |
I know this is an ancient thread but for future reference ANSI Z535.4 has a table of recommended letter heights vs viewing distance.
| Top |
Page 1 of 1
[ 8 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
