| Author |
Message |
egabe1
Post subject: Capacitive test points - phasing Posted: Thu Apr 24, 2025 6:28 am |
We are looking to hot phase between two 15kV cables. These cables have Tyco elbows installed on the ends of them which include a capacitive voltage test point. When using these test points, what kind of safety precautions need to be made?
| Top |
mpparent
Post subject: Re: Capacitive test points - phasing Posted: Fri Apr 25, 2025 7:58 am |
Use a hot stick / shotgun to take them off. Then you can use your proximity tester (attached to a hot stick / shotgun) to test for 0 volts.
Mike
| Top |
Page 1 of 1
[ 2 posts ] |
