It is currently Sat Oct 24, 2026 7:14 am
 Post subject: Ir testing of switchgear
PostPosted: Thu Oct 07, 2010 1:46 am
We have people who do ir testing of our main switchgear by testing from the front of the gear, my opinion is that i don't think you can test much from the front. Can we put some type of window or sliding cover on the back cover panel for a better view ? The cover panels are about 3' wide and 7' high. This access would test the wiring connections along with swichgear connections.
Open for any suggestions.
PostPosted: Thu Oct 07, 2010 4:56 am
There are several manufactures that make IR windows for this purpose.
PostPosted: Thu Oct 07, 2010 12:43 pm
What you should do is to place IR windows on anywhere that needs scanning, typically IR windows are a couple of inches and you would need 2-4 windows, they are fairly inexpensive and easy to install, about 300 bucks per window, some IR providers are:
Iris IR
Flir
Gratton Infrared Services
