It is currently Mon Oct 19, 2026 3:58 pm
 Post subject: Molded Case Breakers
PostPosted: Tue Jan 25, 2011 4:43 pm
Has anyone seen a remote actuator (open & close) for paddle operated molded case breakers?
PostPosted: Tue Jan 25, 2011 4:57 pm
Yes,
I know that Squared D has motor operators for some of their breakers, so I assume other manufacturers do also.
PostPosted: Tue Jan 25, 2011 7:39 pm
GE sells a motor operator for their breakers as well. Are you looking for a portable device that could be mounted on a breaker as needed, or a permanently installed device? The motor operators I am aware of are meant for permanent installation.
PostPosted: Tue Jan 25, 2011 8:43 pm
Many of the newer styles have them available, but expensive. There are remote operators that can be moved from place to place (Using magnets) and that can be operated remote via wireless remote. Whole system for about the cost of one of theose operators.
PostPosted: Wed Jan 26, 2011 10:32 am
Square D no longer makes the motorized QO breakers. The only ones available now are for their smart panels. The old ones you could put into any panel that aceepted QO. The new ones only fit the smart panel. Don't know why they dropped it as it was a great product.
PostPosted: Wed Jan 26, 2011 4:50 pm
I'm looking for a portable device, similar to a Chicken Switch, but strong enough to CLOSE a panel mounted 600A molded case CB.
PostPosted: Wed Jan 26, 2011 5:43 pm
That is exactly what I was talking about, my company makes them.
PostPosted: Thu Jan 27, 2011 11:09 am
Zog,
Which company are you working for? Can you give me a link. Thanks
PostPosted: Fri Feb 11, 2011 9:11 am
Intrest here also
Zog - Please post a link. Thanks
PostPosted: Fri Feb 11, 2011 11:58 am
I think that violates forum rules, but you can PM me.
