It is currently Mon Oct 26, 2026 8:37 am
 Post subject: Nfpa Journal - Electrical System Maintenance
PostPosted: Sat Jan 28, 2012 1:54 pm
The current edition of the NFPA Journal has a good article about electrical maintenance. (Use [url='http://www.nfpa.org/publicJournalDetail.asp?categoryID=&itemID=43863']this link to read the article[/url].)
The article points out that we should not let other priorities distract us from needed electrical maintainance, and it identifies overcurrent devices as being at the top of the list. The article states:
"Although all electrical equipment needs to be maintained, the most important, from a safety standpoint, are the overcurrent devices that trip circuits when a fault occurs. These determine the length of time the overcurrent conditions exist, which determines the amount of heat, energy, and damage that will occur."
But, the article also points out that other areas also need to receive maintenance attention.
Related Past Posts
[url='http://www.labelprinters.org/blog/2006/10/arc-flash-safety-checklist.html']Arc Flash Safety Checklist[/url]
[url='http://www.labelprinters.org/blog/2008/01/new-arc-flash-labeling-best-pactices.html']Arc Flash Labeling Best Practice Guide Available[/url]
[url='http://www.labelprinters.org/blog/2008/08/system-maintenance-key-part-of-arc.html']System Maintenance A Key To Arc Flash Safety[/url]
$70 value free! 130 page [url='http://www.arcflash.me/gift-arc-flash-handbook.php']Arc Flash Solutions Handbook[/url]. This handbook will walk you through the necessary steps for implementing an arc flash assessment as part of your overall safety program requirements.
[url="http://feedproxy.google.com/~r/Nfpa70e/~3/0lmgc0cSoEw/current-edition-of-nfpa-journal-has.html"]Continue reading...[/url]
Arc Flash Forum News Feed
